Slack app
How to notify teams in specific Slack channels on conversation and ticket activity in Intercom.
Beth-Ann Sher avatar
Written by Beth-Ann Sher
Updated over 2 months ago
Intercom's Slack integration makes it easy to notify teams in specific channels on conversation and ticket activity.
Note:
  • Slack is a free app for some features. You may be required to upgrade to a paid Slack account to access all features. This app is available on our Advanced and Expert plan.
  • This app does not support Slack as an inbound support channel. If you're wanting to support your customers on Slack and route all conversations directly to the Inbox, use the Channeled integration.
Install Slack app
You’ll find Slack in the Intercom ​​App Store. Click Install now to add it to your ​​Intercom workspace:
Intercom permissions
Authorize Slack access to your targeted Intercom workspace. We ask for the following permissions:
  • Read conversations - View conversations.
  • Read admins - List and view all admins.
  • Read one admin - View a single admin.
  • Read one user and one company - List and view a single user and company.
Slack permissions
Allow Intercom access to your targeted Slack workspace. We ask for the following permissions:
  • Chat:write - Post messages in approved channels & conversations.
  • Groups:read - View basic information about private channels that your Slack app has been added to.
  • groups:history - View messages and other content in private channels that your Slack app has been added to.
  • channels:read - View basic information about public channels in a workspace.
  • channels:history - View messages and other content in public channels that your Slack app has been added to.
The app is now installed across both the Slack and Intercom workspaces. A channel can begin receiving notifications once the app has been invited and the Workflow has been configured.
Note:
  • It's currently not possible to connect multiple Slack accounts with one Intercom workspace.
  • To add multiple Intercom workspaces to a Slack space, the third-party app Zapier may be able to assist.
  • If you run into "This slack team is already integrated with another workspace" error while installing Slack, you will need to remove this Slack workspace from the Intercom workspace it's already connected to.
Configuration
Invite app
Invite the Slack app into your selected channel using the /invite slash command or click the slash button and select "Add apps to channel".
Then search for the Intercom app and click Add.
If your workspace has their data hosted on our EU or AU servers then you will need to add Intercom EU or Intercom AU instead.
Once the app has been successfully added to your channel you will receive a welcome message prompting you to configure a Workflow.
Using Notify Slack channel step in Workflows
Now navigate to AI & Automation > Workflows and set up a Workflow using the Notify Slack channel action step.
First, choose a trigger for your Workflow such as "When a ticket is created".
Build your Workflow and add a Notify Slack channel step.
Select a public or private channel you'd like to receive notifications into.
If you don't see a channel in the channel list, make sure that you've added Intercom app into this channel.
You can use branches to reduce noise or target specific conversation or ticket attributes.
Once the Workflow has been set live you should start to receive notifications in your selected Slack channel.
If the Set live button is disabled, check that you've added all parts of the workflow fully.
Notifications in channel
If the notification is set up for tickets, it will include the top 3 ticket attributes, however if it's set up for conversations, it won't include any attributes. The first notification for an individual ticket is posted as a message in the channel and subsequent notifications are then posted as threaded replies.
Notifications will include top 3 non-empty attributes and empty attributes will be filtered out. If there are less than 3 filled attributes, only the filled ones will show. This only sends attributes for the "A ticket is created" workflow, not, for example, the "Teammate changes the state of a ticket" workflow.
Note:
  • It's currently not possible to notify a Slack channel when a customer responds to a survey.
  • Slack notifications do not include replies from Fin AI Agent.
  • This only sends attributes for the "A ticket is created" workflow, not, for example, the "Teammate changes the state of a ticket" workflow.
Uninstallation
In the Intercom App Store, search for the Slack app and click Uninstall from the landing page.
Select a reason for uninstalling the app. Type in "UNINSTALL" in upper case and then click Uninstall.
The app will now be uninstalled from both the Slack and Intercom workspaces.
You will have to manually remove the "Notify Slack Channel" action from your configured Workflows.
FAQs
Can I support customers on Slack?
Yes, if you want to connect Slack as a support channel in Intercom, you should use our Channeled integration which allows customers to reach out to you on Slack and routes these conversations directly to your Intercom Inbox, enabling you to handle your Slack support from one place.
However, if you're just wanting to notify your teams in Slack about conversation and ticket activity, simply use our Slack app.
💡Tip
Need more help? Get support from our Community Forum
Find answers and get help from Intercom Support and Community Experts
Did this answer your question?
